I recently had a power outage and didn’t receive a notification. I have other notifications set up for various things, but that obviously is not one of them. Is that something that is able to be set up or not? If so, how do I set up the notification of a power failure. With winter coming, I want to make sure that is active if it is able to be.
Yep, that is definitely something you can setup. You can do so by going to the “Notifications” tab, there should be a notification called “System Actions to Watch”. Simply edit it to take power failures into account.
Keep in mind that the panel is setup to report a power failure only after it has gone on for 10 minutes. This is to reduce the number of false notifications for temporary losses. If your notification is already setup with power failure notification, it’s possible that the power was simply not out long enough to trigger a notification.
