It is being reported that with the initial release of the GC3, even though it ships with the 802.11 hardware, WIFI functionality is not operational at this time (and neither is the hardwired Smoke detector terminal blocks).
It will most likely be enabled via a future firmware release.
I believe they were improving the interface that was being used for Wifi. I cannot say for certain.
It is fairly common that features may be unavailable at release (not quite the wide release as you might see with other electronics), but the hardware is in the panel so it only needs “turned on” so to speak through firmware.
Hi Jason, if the wifi isn’t enabled yet, and enabled at a later date, do users need to pay in order to get the firmware push, like the GC2, to get wifi enabled?
I asked Nortek what their plan was for releasing a panel similar in function as the TS1, but for the GC3 and this was their response:
“The TS1 has an entirely different user interface so it will not work the new GC3. Our GC3 will have its own secondary keypad later this summer. Currently our PAD1 is used a secondary keypad for the GC3.”
Hmm, check your sensors you have learned in to make sure the same serial number is not listed twice. Have you added other sensors in this same programming run?
I did the take over module only so far for wired sensors, those numbers are different. Has anyone successfully already added this pad to GC3? Just want to make sure it’s not a general problem with the units.
Going to try power cycle when I get home. Is there a correct way to do this? I was just going to unplug the transformer and battery.
