Our new home has some no-neutral wiring that require Z-Wave switches. I’ve done extensive research and the GE / Jasco Enbrighten In-Wall No-Neutral Smart Dimmer
52252/ZW3012 are no longer in production. I am trying to avoid paying an electrician to rewire my garage. Any suggestions on how to make this work?
An alternative may be to use a relay at the light fixture like the Zooz ZEN51. You would still have control via your current switch plus zwave control.
Thanks! Looks like I can make that work by putting the relay in the actual fixture where the neutral line is.
Another potential option is the Inovelli Red Series switches, I believe those can be used without Neutral.
