I feel like this should be easy but I haven’t been able to find it in the manual or the forum. How do I set it so there is no entry delay on any sensor when arming in stay mode?
Is there not an option to arm “no entry delay”? otherwise I suspect you may want to program entry/exit delay sensors as perimeter.
You can choose to disable the entry delay when you arm from either the Qolsys panel or the Alarm.com app.
I have a related question…but I see where you can hit “Entry delay OFF” on the arm page. I think this is what the OP was asking about.
However, when you ar. The system in “stay” mode, why does is still have a 60 sec count down timer. Can you instantly arm the system, with no count down?
The exit countdown happens every time. Even when arming in stay mode. The closest thing you can do is turn off the exit sound when arming and do a silent exit. It still will won’t be armed until after the exit delay. This allows you to arm the system for others and exit before the system is armed.
I dunno, perhaps Qolsys is different for alarm.com, But when I arm my panel via alarm.com it is instantaneous, and there is no exit countdown.
That’s true, there is no exit countdown when you arm from Alarm.com. But when you arm from the panel in stay mode it still does an exit countdown.
Is there a setting for that? When I arm in stay from either the panel or the app, it’s instant. No countdown.
There is if you are using a Qolsys IQ panel.
Check Settings - Installation - Security and Arming - [Arm Stay, No Delay]
I believe the above posts stating an always on stay countdown may have been assuming 2GIG use.
