Hi there -
Anyone ever had to re-map the buttons of an ACT-34B wireless transmitter in a Linear AP5?
The mfg instructions give five button options but doesn’t specify which buttons on the ACT-34B they are referring to (not QUITE true; they use general directions like LEFT button, Right Button etc…but not clear which is up and down on an ACT-34B in their way of thinking about it.)
Its an existing system with a whole bunch of fobs already programmed into the AP-5 so am not keen to mess it up (its for a garage door opener on a high-rise).
WHy am I asking about re-assigning buttons, you ask? Well…there is some weird behavior happening where pressing the smaller grey button triggers another nearby AP-5 as well as opening the garage door. Not even sure if its possible to confuse the AP-5 to open both relays K1 and K2 from messing around with it, but it appears a previous property manager might have done just this (not clear, so not blaming anyone specific!).
Any advice will be much appreciated!
PS. A second related q: We ordered a bunch of ACT-34Bs recently and it appears this latest batch has a separate serial number associated with each button. This is great for security but, do you happen to know if its possible for both the older existing fobs (with only a single serial number for ALL the fob’s buttons) can co-exist with these newer fobs with separate serial numbers for each button, or do we have to replace ALL the fobs with the newer style for it to work?
