I have a TL880LTVZ and can’t login yet because it hasn’t communicated with alarm.com and I’m not sure what is wrong. When trying to press 3 nothing happens and *8 851 asks me for a subsection.
I already did 382 opt 5 and 300 alt comm auto.
There are a few options when running a cell test.
When pressing the [3] key are you holding it for two seconds? That can prompt a cell test.
After pressing 851, can you scroll to Communications Test? If so, press the [*] key to run the comm test. Upon completion, the keypad reads Test signal sent OK. Any change
The full process should be:
Press [][8].
Enter the installer code.
Press [851] to enter Interactive Services.
Scroll to Communication Test.
Press []. Upon completion, the keypad reads Test signal sent OK.
I can hold for 10 seconds and nothing happens. *8 master code 851 brings me to “enter subsection _ _ _”. Is there another way to check to see if it sees the module?
FYI anyone having trouble with the TL880LTVZ, the TX/RX wires are supposed to be reversed. Issue resolved by reversing cable to the PCL-422.
Hi pt0001,
Thanks for the update! To make sure I understand, you’re saying make sure the TX wires on one device are connected to the RX wires on the other, correct?
Correct. TX+ to RX+ TX- to RX-.
