Thermostat scheduling is not opening when I click on it? I had previously setup when my system is armed to adjust my nest thermostat, are you still supporting this feature?
NEST integration is available through Alarm.com (with the Gold Interactive plan). However, scheduling rules/automation has never been an available feature with said integration.
The following features are available With Nest Integration and Alarm.com:
- Current target temperature control
- Current mode control (Heat, Cool)
- Temperature notifications
Smart away is the feature you are referring to. These options are available for Z-Wave thermostats but not NEST thermostats.
Have you only used NEST thermostats with Alarm.com or were any Z-Wave thermostats used previously?
