Hi, my old MyQ Chamberlain garage door opener died today and I had to replace it. Can I get someone to reset my gateway so i can add the new opener in there?
Thanks!
Thanks!
No problem, I have sent a command for you to clear out the Gateway. Wait a few minutes then you should be able to go ahead and re-install the new door under Settings > Devices > Automation Devices > Liftmaster Installation in the Alarm.com website.
Hi Nick
I entered the serial for the gateway and it took a while for the automation devices to come up. I clicked the +lift master and followed the directions but it never connects to the opener. I have a Chamberlain B1381 if that helps.
The B1381 is a MyQ overhead with built in Wifi Gateway. Is the serial number you entered the MyQ serial number off of the Overhead unit itself?
No, that was the internet gateway that I had to buy with the last garage door. If I need to enter the serial from my opener, I’ll need you to reset it again.
No problem, I have sent a command to remove that Gateway. Yes, your Wifi overhead should act as its own Gateway. Add the MyQ Serial number printed on the overhead controller.
Thanks Jason, I’m all set now!!!
Mail](https://go.microsoft.com/fwlink/?LinkId=550986) for Windows 10
