Need to disarm my device
My “Vivint go” home security device has got armed. I don’t know the pin to disarm it as I am the new owner of my house. Please help me to disarm it.
Are you referring to the Go!Control panel, found here?
If so, the default Installer Code is typically 1561 and the default Master User code is 1111
Vivint may be able to assist you better with this, we would not have any specific codes for your panel.
Your realtor or the previous home owner may have the current code as well.
Thank you for responding. I have talked to both realtor and the previous owner. The previous owner said that, they never used it before and they don’t even know the code as well.
At this point your best bet for finding the current code is through the provider but they may not release that information, if they have it.
If you arent using the panel, and its not connected to service, you can always just power it down (power supply first from the wall then internal battery) but the panel will go into an alarm state once you open the panel. Additionally the panel will boot into an alarm state once power is reapplied.
