My Q Garage Door Integration
First of all, I highly recommend that anyone that is trying to integrate your older garage door opener into ADC and alarm panels to just replace your garage door opener with a complete system. Garage door openers are not expensive and the interactive interaction instructions make this an easy 1 person job!
My Linear and my Q add on did not work well. You can see my posts of my garage door problems with this band aid solution. If anyone wants a used Linear add on garage door z wave unit, make me and offer and DM me.
My question is this: I have an IQ4 panel and on my garage door I have wireless magnetic sensors. I have these so I can get the voice announcements when I open and close garage door as well as tie this into rules and automation.
If I removed the sensors, would I still get announcements and be able to use automation with the built in My Q garage door that shows open and closed via the ADC My Q gateway?
My goal is to eliminate redundancy here (sensors and the new MY Q opener that senses open and closed)
MyQ openers can be linked in Alarm.com and can be used to generate Alarm.com notifications, however they cannot cause voice announcements on the alarm panel and cannot be used to trigger alarms. The separate magnetic sensor would be used to communicate to the alarm panel.
