Hi Surety experts
I have two garage doors and bought 2 myq chamberlain G301 for both.
I know that in the past it had to be registered to either myq or alarm.com and not both, however the myq website says “it seamless work with alarm.com”
As i did not found any documentation on how to setup both together I did setup one garage door with alarm.com and another with myq app.
Then I try to do the other way around with the already registered devices.
When I try to register on alarm.com the device that was registered with the myq app it gives an error and does not allow me to proceed (I guess because it is registered on myq)
When I try add on the myq app the device I registered on alarm.com it recognizes that the device belongs to alarm.com but the error message says the following “This device belongs to an active alarm.com account. Please use the same email id that was used with Alarm.com account to login to myq”
That message gave me some hope, specially because it made sense as I was using an user id and not an email to login to alarm.com.
I changed my alarm.com account user id to my email and now I login with the same email on both accounts but I still got the exact same message.
Do I still got the message because I was not using email address to login to alarm.com when I added the garage door opener? If this is the case I guess remove and add again should fix it.
Does anyone knows any other path to make both work together?
Tks
Cristiano
