I am hoping for some guidance on connecting the Mr. Steam home automation module to my Qolsys panel to turn it on remotely. The following specifics in the manual appears to pertain to what I am trying to accomplish.
I have a Qolsys IQ Panel 2 and I am mainly wondering what device I would need to purchase (presumably one that emits a “momentary contact closure” signal. Thank you very much in advance for your assistance.
2 wire pairs (not supplied) must be provided to connect the Home
Automation system and the Home Wizard.
• Using the supplied connector, connect the signal wires and feedback
wires from the Home Automation system to the Home Wizard.
The signal from the Home Automation system must be a
momentary contact closure to turn the Steam Generator ON or OFF.
A sustained contact closure or voltage will damage the Home Wizard.
• The feedback from the Home Wizard is a sustained contact closure
when the steam generator is ON and an open circuit when the steam
generator is OFF.
The maximum voltage for the
feedback circuit is 2A at 12 VDC
