Greetings,
I’ve got an OLD (originally Brinks from 2005) ADT-monitored system based on BHS-3000 with hardwired sensors that I want to move forward from because it requires maintaining landline phone service (there is only Verizon with cellular coverage in our area and the only module for the old hardware is GSM-only = AT&T). There are a number of door sensors (some wired in series) as well as a smoke sensor and I seem to recall also a heat-sensor for fire hidden away in the kitchen as well as a siren (probably not piezo, but not sure). There are two BHS-3000 (one on each floor) connected to the control panel in a box in a closet where the power is connected and all the wired sensors and the control panels terminate. I am trying to figure out what of this would be salvageable if I moved to an IQ4 system, presumably using a hardwire 16F to tie in the existing sensors, and what would be involved in making it happen. I’ve only done some cursory searching, but don’t find much in these forums on my situation (for example, searching for the BHS-3000), so I figured I would ask.
Any advice?
Thanks,
Tim
