Mounting ADC-V721W Upside Down?
If I mount it upside down, does alarm.com have a function to “flip” video?
Thanks,
RR
Found there is a setting on alarm.com to control this!!
In your Alarm.com account go to Video-> Video Device Settings. Select the Camera in question and click Video Device Image. From there you should find a checkbox to flip the image.
Thanks, that was the trick!
Glad to help!
What if I only want to rotate it 90 degrees? Is that possible?
It is not currently possible to rotate the image 90 degrees though Alarm.com. The flip mentioned above is for 180 degrees.
The mounting arm is meant for installation in upward fashion (or downward if it has overhead protection).
Is it something that might be added in future? It’s really frustrating not being able to rotate.
We are happy to forward all requests, but in this case I would urge that the takeaway would be that the V721W should not have its mounting arm mounted sideways. The way the rotation arm works you would not be able to mount the camera in an upright position that way.
The 45 degree mounting arm should be facing up when installed on a wall.
The camera offers a better view in this specific case, if I tilt it sideways. I managed to hack it on the alarm.com website using a bit of javascript, but it really should be a setting in the system.
