I have ring right now, switching to surety when my house is built in may. My 60lb dog doesn’t set off ring motion detectors. Yes they work, we trigger them no problem. I have them mounted about 8ft high.
With so many different brands, is there a specific brand I should look to that would be better?
On ring, you can change the sensitivity so I have it set to low. Not sure if this is an option with certain sensors for surety. Thank you!
I mean with large dogs like that I usually recommend moving the motion sensor down to about 4ft off the floor and turn the motion sensor upside down to where it’s looking out and up instead of out and down
A list of tested compatible sensors for the IQ Panel 4 can be found in the below guide. However, none of the motions listed are rated for a dog that size, they all cap out at 40Lbs.
All IQ Panel 4s work with PowerG and one legacy sensor type, 319.5, 345, or 433.
The one we offer on our storefront works with 319.5MHz and PowerG.
