I programmed all my sensors (which was far easier thsn I thought BTW)
I have several motion detectors programmed in. They all have custom names. All are set without a chime or voice reading the name out loud.
Every hour or sometimes ever other hour the panel’s audio announces “motion Activated”. I have nothing named just “motion”
I can’t figure out how to stop it and don’t want to swap panels in you system out of fear that I’m will get false alarms every hour
Checked my ADC history and no history of these motion triggers (there are triggers for things we are familiar with e.g. my wife went in hall at 3:17 to sleep in the other room because the iQ 4 was announcing an alert ever hour)
Also, this is happening when there is no activity in the house. We are sleeping so no one or nothing should be tripping sensors
Hmmm I’m kinda drawing a blank at the moment on what would cause that issue I will continue do some research but if I don’t get back too u one the tech support guys can will be able to help tomorrow
changed the motion to Loop 1. Seems to have stopped. Will post again of things change.
Good catch.
The Loop number for a Honeywell compatible sensor will not always learn in as the appropriate sensor reporting loop. Frequently you might see a DW contact learn in showing Loop 1, but the reed switch uses Loop 2.
Always be sure to set the loop number per manufacturer instructions of the sensor.
Most sensors will be Loop 1, Reed Switches for DW contacts are typically Loop 2, Recessed 2GIG DW are Loop 1.
Smoke/Heat/Freeze and other multi-function devices will have multiple loops for different functions.
If you have any questions about the Loop number for a sensor, let us know. Reporting irregularities or a lack of reports completely are common results of Loops being incorrect.
