Monitored Fire Alarm
Does Surety offer a monitored fire alarm only? I already have security, but my insurance is requesting that I add a monitored fire alarm.
Yes, if you have a home alarm system monitored by Surety you can just add compatible smoke detectors to your system for fire monitoring.
The monitoring plans on our website all include fire monitoring, there are no separate fire and security plans.
OK, we currently have security with a different company. Do we have to have our home security through you in order to add the module or can that be ordered and monitored as a standalone?
While I cannot speak for other providers, in general, your security monitoring company should be able to provide you with a “proof of monitoring” certificate to give to insurance. If fire is being monitored by your system/service provider, then fire should be reflected on that certificate. You may need to reach out to them directly for more information.
It is not a standalone service.
If you have security monitoring service through Surety, to have Fire Monitoring reflected on the monitoring certificate, you would need:
  • a compatible alarm system,
  • a security plan with monitoring,
  • and a smoke sensor programmed into that system.
OK, we will cancel our current provider and order a system through Surety as long as we are able to get a certificate showing that we have fire monitoring.
I need you to tell me exactly what to order for security and fire monitoring.
To confirm, what system/equipment do you have already? Some or all of it might be compatible with our service. We’d be happy to check, just let us know!
When starting from scratch, we typically recommend the Qolsys brand IQ Panel 4, it works with 319.5Mhz and PowerG sensors as well as Z-Wave devices.
Both of the following smoke detectors can be paired with it:
If you are monitoring for security as well, you would want Door Window Contacts, Motions, etc. The type and amount would be dependent on your specific build/use case.
You can use the filters on our store page to find compatible equipment for the panel in use, The link below would cover the devices we sell that work with the aforementioned IQ Panel 4 IQP4001.
Fire monitoring is built into all Surety plans. If you already have a Surety system, just add compatible smoke detectors to meet insurance requirements easily.
