Matter Devices with Alarm.com
Matter is a smart home standard that lets devices from popular brands like Jasco, Leviton, Philips Hue, and IKEA work together across platforms such as Alarm.com, Apple Home, Google Home, and Amazon Alexa. Matter devices connect over your home Wi-Fi network with improved reliability and strong security.
With a compatible Surety system, you can add supported Matter devices to Alarm.com yourself and control them alongside your security system. You can add devices one at a time, or add a supported bridge (like a Philips Hue Bridge) to bring in all of the devices connected to it at once.
:information_source: Matter support is growing. Right now, only the Matter lighting devices listed below are supported. We expect Alarm.com to add support for more Matter device types in the future, and we’ll update this topic as that happens.
Requirements
  • A compatible panel: IQ Panel 5, IQ5 Hub, or IQ5 NS running software version 5.1.1 or later
  • An Alarm.com plan that includes lights / home automation
  • The Alarm.com app on your phone or tablet
    • Matter devices currently must be added using the Alarm.com app. Adding Matter devices from the Alarm.com website isn’t available yet, but may be in the future.
  • Your panel and Matter device on the same 2.4 GHz Wi-Fi network
  • A supported Matter Wi-Fi light device or bridge (see below)
Supported Matter devices
Jasco
Device Model
JascoPro Wi-Fi Smart RGB Bulb, A19 81886
JascoPro Wi-Fi Smart RGB Bulb, BR30 81889
JascoPro Wi-Fi Smart RGB Surface-Mount Light 81901
JascoPro Wi-Fi Smart Plug with Tethered Push Button 81910
JascoPro Wi-Fi Smart RGB Retrofit Downlight 81892
JascoPro Wi-Fi Smart Scene Switch 81914
JascoPro Wi-Fi Smart Rocker Switch 81919
Leviton
Device Model
Decora Smart Wi-Fi 2nd Gen Switch D215S
Decora Smart Wi-Fi 2nd Gen Dimmer D26HD
Decora Evolve Smart Switch Module VM2S1
Decora Evolve Smart Dimmer Module VM2D3
Bridges
Bridge Notes
Philips Hue Bridge Adds the Hue lights connected to the bridge
IKEA Dirigera Bridge Adds the IKEA lights connected to the bridge
Add a Matter device
  1. Open and log in to the Alarm.com app.
  2. Tap the Menu icon (☰).
  3. Tap Add Device.
  4. Tap Lighting and Appliance Control.
  5. Tap Matter.
  6. Follow the on-screen prompts.
  7. When asked to scan or enter the device’s code:
    • New device (not set up in any other app): Scan the Matter QR code on the device. If you can’t find a Matter QR code, check the device’s manual or packaging.
    • Device already set up in another app (Apple Home, Google Home, Amazon Alexa, or the manufacturer’s app): Generate a Matter pairing code in that app, choose that the device is on another system or app, and enter the code.
:bulb: Adding a bridge? When you add a Philips Hue or IKEA Dirigera bridge, all of the devices connected to that bridge will appear in Alarm.com.
:bulb: Tip: When adding a brand-new Matter device, the panel and device talk directly to each other during setup. If you have trouble, temporarily move the device (or panel) closer together and closer to your Wi-Fi router.
What you can do with Matter devices
  • Control and check the status of your devices remotely in the Alarm.com app
  • Create automation rules and schedules
  • Add devices to Scenes
Limitations
  • Matter devices don’t show up on the panel’s touchscreen. Use the Alarm.com app to see and control them.
  • Matter devices don’t report problems (like being offline) to Alarm.com the same way, or as quickly, as Z-Wave or PowerG devices do.
  • Device names you set in other apps (like Apple Home or Google Home) may not carry over to Alarm.com, so you may need to rename them.
Using Matter devices with other apps
One of the benefits of Matter is that the same device can be controlled from multiple apps at once, such as Alarm.com, Apple Home, Google Home, and Amazon Alexa.
Share a device from Alarm.com with another app
If a device is already in Alarm.com and you also want to use it in another app, generate a pairing code from the Alarm.com app:
  3. Tap Manage Devices.
  4. Under Lights and Switches, tap the device.
  5. Tap Device Settings.
  6. Under Connections, tap Start Matter Pairing Mode.
  7. Tap Copy if you’d like, then enter the pairing code when the other app asks for it.
Remove another app's access to a device
Any app connected to a Matter device can remove another app’s access to it. To remove an app’s access from Alarm.com:
  6. Under Connections, tap Remove next to the app you want to disconnect.
Troubleshooting
If your device won’t pair, start with these checks:
  • Already set up somewhere else? If the QR code or pairing code on the device doesn’t work, the device may already be connected to another app (Apple Home, Google Home, Amazon Alexa, or the manufacturer’s app). Get a pairing code from that app and use it instead.
  • Same Wi-Fi network: Make sure your panel and the Matter device are on the same 2.4 GHz Wi-Fi network.
  • Wi-Fi signal: Make sure both the panel and the device have a good Wi-Fi signal. If the signal is weak at either location, you may need to move the device or your router.
  • Distance: Bring the panel and the Matter device near each other to finish setup.
Device Authenticity error
This message can appear during setup but doesn’t prevent the device from being added. Tap Proceed to continue.
Device Configuration error
  1. Tap Retry to try the configuration step again.
  2. If that doesn’t work, power cycle the device (turn it off and back on) and start the setup again.
  3. If it still fails, factory reset the device (see the device’s manual) and start the setup again.
Device won't go into pairing mode
  1. Check whether the device is already connected to another app or system.
  2. If it is: Use that app to generate a Matter pairing code. Then start the Matter setup in the Alarm.com app, choose that the device is on another system or app when asked, and enter the pairing code.
  3. If it isn’t: Factory reset the device (see the device’s manual) and try again.
Setup keeps searching for the device, or times out
Make sure the device is powered on and in pairing mode. Pairing mode usually times out after about 15 minutes, so try this:
  1. Power off the device.
  2. Start the Matter setup again in the Alarm.com app.
  3. Before you enter your Wi-Fi credentials, power the device back on and let it enter pairing mode.
  4. Enter your Wi-Fi credentials and tap Next.
  5. Continue with the setup.
Need help?
If you’re still having trouble, post a new topic in the Support category. Include your panel model, the Matter device you’re trying to add, and where you’re getting stuck.
