Hello
Since the first time my panel connected I have been getting this error “Malfunction (Garage (ID:5))”
thank you
Hello
thank you
That would be the Linear GD00Z Z-wave garage opener. The device is showing communication issues. This could be due to a few things.
In this case I see the GD00Z is actually the only Z-wave device on the network. How far away is it from the 2GIG Panel?
The Linear GD00Z Z-wave garage opener is already paired to smartthings hub, and it is functioning. I haven’t tried to pair it with the 2gig panel. Can I keep using the “Linear GD00Z Z-wave garage opener” with smartthings hub without having this error?
This would mean that the opener was previously connected to this panel and was defaulted and added to Smartthings without being removed from the panel, so a ghost instance of the device is still there. As long as the device is unreachable by the alarm panel we can send a command to delete the instance of it in the panel.
If you would like us to try that please confirm.
Yes please I confirm.
thank you
Circling back on this, multiple deletion commands have been sent but they have been unsuccessful as the device is powered and functional.
As it is your only Z-wave device listed you can instead remove the garage opener and clear the Z-wave network on the panel by going to Services > Zwave > Wrench Icon > Installer Code > Advanced Toolbox > Reset Controller. This just resets the Z-wave network.
I reset the the controller
Looks like that device is no longer listed. You should be set.
error is gone
thank you
