Making the 2GIG GC3 Switch
I see you guys are now selling the 2GIG GC3. Can you tell me if the 2gig door/window contacts will work with the new panel?
Will I be able to set up the 2GIG GC3 panel on your Gold Interactive Monitoring plan?
Thanks
You should be able to use any 345 Mhz sensor with the GC3. Specifically the 2GIG DW10 door/window contacts will work with the new panel.
You will be able to use the GC3 on the Gold Interactive Package.
Thank you Tyler.
Do you know if the 2GIG TS1 will work with the GC3 or if they are coming out with another secondary screen?
Thanks
Unfortunately, there is no way to make the TS1 work with the GC3. The GC3 secondary keypad is, as far as we have been informed, in development since release, so it should enjoy a sooner release than the IQ2 or TS1 did. There is just no release date at this time.
