Low Battery Warning Causing Panel to Beep
The alarm panel keeps beeping due to a low battery. I removed the power wire but the panel keeps beeping, what do I do?
Happy to assist!
Removing the panels power cable (transformer) will not clear the alert. The panel has an internal backup battery which will temporarily keep the panel powered without the transformer plugged in.
To acknowledge a trouble alert (such as a low battery) press the Security button (from the home screen of the panel) then click on the yellow triangle button. This will let you view the current trouble condition(s). Clicking on the OK button will temporarily acknowledge the alert and stop the beeping.
The underlying issue will need to be resolved however. In this case it appears that the Basement Driveway 2 perimeter sensor is reporting the low battery. The battery on this sensor would need to be replaced to resolve the issue.
To better assist what is the make and model of the sensor?
