Low Battery Alarm
I can’t get low battery alarms to clear even after replacing the batteries
It looks like this may be regarding Glass Break detectors on the system, is that correct?
What model of sensor are they? Are these 2GIG GB1 Glass Break Detectors?
If so, are you replacing both batteries inside the detectors? Replacing one and not the other will cause issues.
Check the date code on the batteries to verify they aren’t near end of life. Sometimes retailers will have older batteries shelved.
Have these detectors been moved? Or are they further from the panel than other sensors?
