I set up lighting schedules and curious what happens if you (for example) turn off a light while it’s supposed to be on for (say) 4 hours. If you flick it back on, will the schedule still close the loop and turn it off at the end of those 4 hours?
If you leave it off, will it turn itself back on to finish that schedule?
You can test this in real time but the light should follow the rule as it is written, regardless of what occurs in the interim.
For ex, I have a rule to turn on a light at 5PM, then turn it off 10 minutes later. If I turn off the light, then on again, in that ten minute time frame, the rule will still tell the light to turn off at the end of those ten minutes.
