I have a PG9929 key fob which is rarely used, and I just realized recently that pressing keys do not light LEDs on it. OK, probably dead battery, but I tried 3 different fresh CR2032 batteries and none of them would cause LEDs to light up when I press the buttons. What is strange is that in the process of putting in any of these batteries (including the original), I will see the LEDs flicker blue just as I am beginning to insert the battery. But light activity goes completely dead as I push in the battery the rest of the way. Yes, I am putting them in with the + polarity on top as indicated. I cannot test the key fob from the panel because the IQ panel 2+ it was enrolled in died first, and now I am rebuilding on an IQ panel 4 I recently received from surety.
This all makes me wonder whether the fob itself is faulty rather than just a dead battery issue. This would be a bit disappointing as I only purchased the key fob about a year ago. A quick search reveals a review on Amazon that reports a similar experience with a failed PG9929 key fob.
My question: Is there anything else you could suggest I try to revive the key fob or does it sound like replacement is necessary?
