Issue with Thermostat and Heat not working 2GIG
The furnace is not turning on. The surety system controls it, but there’s a z-wave trouble light on. I changed the batteries, but it’s still not working.
I guess there is a bit more needed in this case to troubleshoot.
To clarify, the furnace is not turning on at all? Regardless of the mode and target temp?
Ultimately, a thermostat is a fairly simple device. It will continue operating normally locally even without remote commands of course. Is the thermostat powered on? Or is the thermostat itself unresponsive locally?
Ignoring the app, etc., right now, what is the current mode and target temp at the thermostat? If your mode is on heat or auto and the target temp threshold is exceeded you either have a malfunctioning thermostat or a serious Furnace issue. This would not have anything to do with remote control and you may need to contact HVAC repair.
If overall lack of function of the furnace is not the issue, could you describe what you are seeing in more detail? We would be happy to help!
