Panel beeping after power outage, how can I stop it?
The beeping you are hearing is most likely in reference to the loss of power. Records indicate that this is a 2GIG Go!Control panel correct?
You will need to acknowledge the trouble alert at the panel. From the home screen press security -> then the yellow triangle warning symbol -> followed by OK.
This will not be a permanent fix however. The alert will come back until the underlying cause (power outage) is resolved.
