I downgraded to surety automate, and switched panels at the same time, and now I don’t have weather – but I’m unsure if someone just has to “push” it down once like has happened to others, or if it is a difference in the plan…
Also, I don’t seem to get any e-mail notifications from alarm.com – is that is a difference in the plan? Or maybe I just don’t know how to use it (since I never got one when I was on surety home, either! :-)?
I’m very new to all this, trying to find the balance!
Thanks for any pointers!
– Rich
PS One last question – is there a way to find the currently registered panel IMEI from alarm.com or suretyhome.com? Thanks!!!
That IMEI is not displayed anywhere, however I can confirm it for you.
However, you would have needed to know this IMEI in order to swap the panel. I’ve sent you the IMEI that is currently registered. Be sure it matches the panel you plan to use.
Weather is not included in Surety Automate.
For notifications, in the Automate plan, arming/disarming and alarms are not supported. You would need to set up sensor activity notifications in Alarm.com. To get started and create some additional notifications login to Alarm.com and visit the Notifications page.
Thanks for the info, as always – this support forum is amazing – one more question – as I am figuring things out, if I switch plans back and forth, do I get charged each time I switch, or just once in the month for whichever plan was the most expensive used during the month? I’m just wondering how much experimenting I can safely do here!
I have two panels one with IMEI ending in 444 and one with IMEI ending in 714 – 714 should be now connected.
I just created a sensor activity notification in alarm.com (pantry door left open for more than 1 minute) and got the e-mail, thanks – that is just what I wanted!!!
Going forward as you make changes it is set up so that you only get charged the prorated difference if your plan costs would increase above what you have already paid that month.
