is there a way to get my alarm.com /watchlight bill down?
It went up slightly. From 12/31 to 14/31 , I have att cell phones and I get good speeds using OOKLA speed test even with 2 bars on my iphone 6. 30MB’s/DL and 10MB’s/UL
Its a good as it gets, On a side note commands from alarm.com seems to be MUCH faster even with the reduced reception.
again. Can it be routed within the panel like the one that came in the CP1
No. it goes in the wall behind panel. Coiling it in the panel is a bad idea.
yes I saw there was no way to coil it in there. I put it in the wall. thanks Riven
Keep in mind cell phone connection quality is not an indicator of Machine to Machine network performance.
In this case, 14 is a fairly solid signal. Yes, you should notice improved network transmission speeds for signals and commands.
In order to boost signal, aside from moving the panel, adjusting the antenna in wall so it is away from all sources of house line voltage is a good idea.
