IQpanel4 - Ambient Temperature Display
Qolsys says that 4.6.1 added this feature:
Ambient Temperature Display: Now, the Dealer, Installer, or Admin user can select up to two (2) compatible PowerG/PowerG+ devices to show their ambient temperature on the Panel UI and Weather Clock.
How do you enable this. I can’t figure it out.
Possibly the issue is what PowerG devices are actually compatible with this feature?
Hi. I think I saw your post on Reddit. Small world. /s
Settings, advanced settings, installer/dealer code, installation, dealer or installer settings
Scroll down to the PowerG section
Indoor Temperature Reporting (allow you to pick the sensor source for indoor temp)
Outdoor Temperature Reporting (allows you to pick the sensor source for indoor reporting)
I believe the list of sensors that will work for temp is the same list that is in this article (But not 100% sure …):
