I’m working on an alarm and video system install for work. Looking at utilizing your business plan for this.
I’m trying to cover 2 building with 1 panel since they are less than 75’ from each other.
The main panel would be in the new admin side with the wall closest to the next building which is a shop. The doors would have sensors and we would have 2 motion detectors and 1 heat sensor and one remote panel in there. It says 2000’ open air but I know things can cause interference.
I was thinking of the possibility of a range extender if needed but DSC PGP9920 isn’t listed on your site.
Also I wanted to get the PGPx934P PowerG + Indoor Pir but you don’t have it listed either.
Just trying to see if it wouldn’t work between the 2 buildings. If not we would have to get 2.
Covering both buildings with one panel
You can set up two partitions on your account, which sounds like what you’re looking for. Each building would be its own partition, so the admin building and the shop can be armed and disarmed separately, all from one panel and one account. The remote panel in the shop would act as the keypad for that building.
Range between the buildings
At about 75 feet, PowerG sensors in the shop should reach the panel fine, especially with a repeater added to the installation. Walls, metal buildings and other obstacles can still reduce range, so we’d recommend testing first if you’re not in a hurry:
Purchase the panel and the sensors for both buildings.
Before mounting anything permanently, install the shop’s sensors and test their signal back to the panel.
If the signal is good, purchase the secondary keypad for the shop.
That way, you’ll know a single panel covers both buildings before ordering the keypad or a second panel.
Range extender and PIR camera motion detector
We don’t carry the PGP9920 range extender or the PGP9934P PowerG+ indoor PIR motion detector with camera. You can purchase them from another dealer and use them with your Surety system.
