Hi. Is it possible to temporarily disable (or bypass) PowerG smoke detectors with an IQ4 panel? For example, if I plan to make some dust from a renovation project, how do I avoid the detectors being triggered…
Thanks
Thanks
I recommend removing the sensor from the system and taking down the device putting it in a cabinet or something so that it don’t get dust in the unit itself
The other poster’s suggestion is a good one. Generally speaking if you are doing renovations and think dust may set off the smoke detector, I would cover the device while the renovation is being actively worked on. A dirty sensor will require cleaning and can impact functionality.
