IQ4 panel with ADC-S2000 temp sensors
Has anyone successfully integrated ADC-S2000 temp sensors? I have several and the HW version 2 ones loose their connection to the IQ4 panel after 24 hours, but not the Z-wave connection.
Please try updating to 4.3.0 firmware. Does this resolve the issue?
@jwcsurety
That is only for new temperature sensors ADC-S40-T as stated in firmware notes. Just FYI
@bracurrie
I have run ADC-S2000 on iq2 and iq4 with out any problems for years untill recently updated to ADC-S40-T sensors.
I am aware, however this is in reference to a separate ticket and the firmware update should be applied.
Update applied. S2000 sensor didn’t reconnect with system, but did show in Z-wave network. Un paired from Z-wave network but is now showing in system check results as failed Sensor.
What is the node ID for that S2000-T?
Wine Rack is the node.
After including the S2000 at 9:13 Jun 09
It is now 9:15 Jun 10. And Wine Rack reports to Mobile App as Offline but on the IQ panel is shows as connected but in sleep mode.
All S40 and S2000 show as sleeping in Zwave test. Zwave test will not test these sensors as they show asleep.
Tried to push pairing button on S2000 to see if I could get it out of sleep status and magically it now shows as back online.
I do not believe they are paying their coders enough to actually solve these issues.
All of my sensors S40s and S2000s now show in the system as asleep so I cannot run a Zwave test.
The S2000 after pairing shows offline after 24 hours.
Today pushing the pairing button on the S2000 to see if it would come out of sleep status stimulated it as back online. Argh
I believe the panel updates broke the sensors.
Temp sensors are wake-up devices which do not respond to pings, rediscoveries, and remote tests. It is expected that they would be asleep. Pressing the button will wake it up and send a status. That is expected.
The odd thing is that the panel is reporting the offline status for those version 2 S2000-T models. If this is happening repeatedly, it seems like the panel may be looking for a response to status pings only, which it will not get.
The TS devices should report periodically or when there is enough temperature change to stimulate reporting. If they do not report in for what period of time that makes the system report it as offline?
For Z-wave I believe it is mostly reactionary to missed commands unless it is a siren, but the default for non-emergency sensors is 24 hours, and it seems like that may be the time-frame in this case.
The panel appears to not handle the data properly from the version 2 S2000-T model. Anything I say would be a guess though until confirmation from Qolsys/ADC.
The behavior is being investigated at this time.
I would hazard a guess then that Surety doesn’t sell the sensors because they have trouble with them.
The remote TS functionality is THE reason I went with Surety/ADC/Quolsys.
I am coming to the conclusion that Zwave is not adequately supported to be said that it’s a feature
The product you are referencing is on our website, but out of stock. We do not sell the new one yet, but it is likely to be added.
I can assure that there is no conspiracy, there is a huge number of supported devices, but I understand that any issues you experience are disappointing if this is the main thing you were excited about using.
The reported behavior is being investigated at this time. I’ll follow up ASAP.
I am skeptical as the TS40 has been available elsewhere and not at Surety for a least a year.
Any update on these issues?
Like @bracurrie, I was excited about integrating remote temperature sensors for thermostat control, since my thermostat is on the other side of the house from my bedroom.
I have a number of the S40-T temp sensors that work very reliably with the IQ4. I see this post was from some time ago. What types of issues are you having?
I do recall when joining them I had some challenges. The trick I found was to be sure to do the following:
1 - Clear the device from zwave first, before joining.
2 - Do the factory default procedure on the S40-T (directions below)
3 - Clear it again from zwave
4 - With the S40-T device in the location where it will live permanently (NOT near the panel!) join it to the panel via z-wave. (This may require running across the house, unfortunately). [Do not use IQ Installer app. Join directly from the IQ 4 panel. Do not use Smartstart.]
4a - When asked for the DSK, do NOT enter the number, but instead scan the QR code from the device / device box.
TIP: For me, the QR codes would not scan. I had to put them on a copier and blow them up to 200% of size and make them darker. Then the copy of the QR code would scan.
5 - Done! Device now joined.
I know this is a crazy process, but for some reason if I keyed the DSK manually, the first temp sensor would work, and subsequent sensors would show up as unknown zwave devices or eventually fall offline. (This is my own process, so the Surety guys may think I’m a little off my rocker here, but this is what worked for me. They’ve been rock solid for months now. I have 5 of these in my home, working with a T40K Thermostat.)
I had a mix of the S2000’s and T40S’s at one point, and I think (if I remember correctly) I had to do a similar process for the S2000s. But at this point I’ve replaced them all with the T40s to get humidity as well.
Here’s the factory reset procedure for the S40-T:
  1. Remove the battery door, tap the tamper switch three times in a row, press and hold the tamper switch for 10 seconds until the LED starts flashing. Then, release to reset to default.
  2. After the tamper switch is released, the LED will blink quickly and then turn solid for 3 seconds indicating that the device is resetting.
I hope this helps.
I’m not seeing any updates regarding the S2000 but this thread is relatively old. Were you planning on using the S2000 or the S40-T? Have you tried using one already?
I was going to get an S40-T, but I stumbled on this thread and wanted to see if there are updates before I spend the money on something that does not work.
The behavior described earlier in the ticket was regarding S2000 Temp Sensors on an older panel firmware version.
Some early S40-T sensors did have a potential issue with reporting incorrect extreme temperature values, this could occur on units loaded with pre-1.1 firmware. At this point though none of the new S40-T sensors should have this issue.
Great. Thank you.
