IQ4 battery life with no power?
My home with IQ4 panel can experience power outages of several hours. When the power goes out, what behavior can I expect to see from the panel?
  • Will the screen turn off to save battery power?
  • How long will the battery last?
  • How do I know when I need a new battery?
  • When the battery dies, I assume we won’t have an alarm system until power is restored, is this correct?
The screen will turn black after a short while once AC Power has been removed.
Roughly 24 Hours, depending on usage and age of the battery.
While you will get a notification that the batter is low/drained, you will not get a specific notification that the battery is end of life. However, if a battery does not charge when the AC power is connected, and the battery is plugged in, there a good chance its time to replace the battery. Battery replacement is recommended around the 5 year mark.
Correct. If AC power fails, and the internal battery dies, the panel will no longer function.
thanks for the information. :slight_smile:
