IQ2 display settings.
I have purchased the IQ 2 panel to go along with my Qolsys, and it all seems to be workin. However, I am quite disappointed in a couple of things:
  1. The screen seems to have weird wave like patters when tapped. Does anyone else have this problem?
  2. The screen is SO BRIGHT! I bought this to keep in my bedroom where we can arm/disarm the system easily. Using the phone is just too cumbersome.
    However, at night the screen is so bright it’s uncomfortable. Can I adjust this? Can the wake sleep functions be tweaked as well? One big reason we got the iq2 was to be able to look at it real quick to see if the system is armed/disarmed, and change as needed without much work.
Thanks!
IQ2 settings can be adjusted under More (apps) - Settings. You can set the screen sleep timeout as low as a 1 minute.
Thanks for the reply. I did find this menu, under “more” - "wifi settings"and then clicking “display”
I am still a little disappointed in the iq2 panel. First of all, the home screen is white, and even with the brightness turned down, it is quite distracting and I don’t see it being a good solution for hard mounting on the wall in the bedroom. If I have the screen shut off in 1 or 2 min, then one of my primary purposes for having a secondary panel is lost. That is, I can’t easily look and see what state the system is in. For example, if I’m in bed and can’t remember if I armed the system, I have to actually go touch the screen to see.
It would be ideal, to have a dark/night mode where the screen is not so obtrusive in a dark room, but still having the visual feedback of the systems status. Is there any what to do this? Are there any other options for me to fill this function?
If you have dropped brightness as far as it will go, there is not any further option at this time that I am aware. I can pass the suggestion along to the manufacturer, however. User and service provider feedback can often result in updates down the line.
Commonly, the IQ2 will use its desk-top stand and be set on a night-stand if used in a bedroom. I don’t believe it was intended to fill in the location of older wired keypads, unfortunately, given its wall-mounting limitations.
I’m on firmware v1.5 (or 1.5.1, don’t have it in front of me) and the only options I get are for wifi and date and time. Am I missing something?
Some settings are harder to find. Display is found under wifi settings (leads to tablet specific settings rather than app settings)
Alright, I’ve confirmed that the latest 1.5 patch does remove that Display option. (It is slated to be re-added)
Also of note, Chime Adjustment specifically I am told will not work (Voice will)
