Has anyone else noticed that the LED does not follow the Nightmode settings? I have the Nightmode set to start at 11:00pm and turn off at 7:00am. It should turn off the display and chime only. It is now 8:00am and the LED is off. If I arm it from this keypad and then disarm it, the LED will stay on. I am assuming it is a bug.
Sounds like the issue from the post below. Check that to see if its what you are running into. The fix should be a firmware update to 4.5.0
Thank you - that resolved that problem - just created another problem…
