Anyone else experiencing major bugs in software with the new IQ Remote PowerG? Tried pairing via PowerG and then via WiFi when testing and found the same issues. Running into several, even after wiping to factory and reconfiguring several times.
Screen won’t come back on after going into night sleep mode, even the next morning (scheduled to enter at 10pm and exit at 7am). Screen still registers touches when black. Power button on right side does nothing.
Screen exhibits same behavior when using right side button to turn off screen.
Battery doesn’t power device at all when unplugged. Double checked that the plastic strip wasn’t still in it, shows 66% charged at power up each time.
To clarify, when the screen is black, you can touch it to wake up, or when the screen is black, touching it still allows for button presses on the screen but the screen stays black?
What software and build version is the IQ Remote panel on? Settings > About > Software/Build
Regarding the battery, how is the panel powered (included power supply and cable? ) is the barrel connector inserted all the way into the back of the panel?
Tyler, thanks for the help - to your first comment, yes, when the screen is black, touching it allows for button presses on the screen but it stays black. The panel is powered via the included power supply and cable, and it’s securely in the back of the panel. It’s been hooked up for a couple of weeks.
Software version is 4.3.0 rc2183_20230417. I’m going to try to reset it back to factory and reconfigure it again this evening just out of curiosity.
Edit: Battery now shows at 99% (says 1 minute, 24 seconds to fully charged but never gets there). Oddly, when AC is unplugged, it still dies immediately.
Thanks - followed the guide to reset and reconfigure. It took the update, seemed to work fine through that, etc. then a few hours later the display went dark and it’s doing the same thing again.
Edit: I did notice when putting a flashlight right up against the LCD that it is displaying info, it’s like the backlight is just dead. It’s obviously not totally dead, which led me to believe it was software. Holding down the power button on the right side and using the flashlight to be able to see how to shut it down, then powering it back on makes it work right again until the backlight goes back out.
I had the exact same issue after turning the Remote PowerG LCD backlight down to the lowest setting. As soon as it went into night mode, the backlight wouldn’t light back up and the screen stayed black/blank. I used @unc81’s flashlight tip to see the pull-down settings and was able raise the backlight brightness to re-enable it.
My PowerG SW version is 4.4.0. When night-time mode is on with panel brightness set to low, the backlight won’t turn back on when touched. However, the unlit screen itself is awake, but requires a flashlight to see the controls.
Sorry for the slow response. Turning the brightness up one click from 0% seems to have resolved it on my end. It’s been working fine the last ~2 weeks.
I was unable to replicate with brightness set to 6% and night time mode set to turn the display off. Screen goes black but then when i touch the screen, it comes back on to a clear brightness.
I’ll pass this along to Qolsys anyway. What build version is your IQ-PG? (Settings > About > Software)
I have another bug with the nigh sleep mode that I have found with the IQ Remote PowerG and the 4.4.0 firmware update.
Mine doesn’t have the same issues as described by unc81, but has a different issue:
When the panel comes out of sleep the next morning, the LED should indicate the arm status (red=armed, green=disarmed.) However, with the 4.4.0 update, the LED status doesnt show either:
If I look at the IQ Hub however, the LED status displays the correct arm status (green or red.) Its only the IQ remote(s) (I have three IQ remotes on my system) that do not display the LED status.
However, once I touch the disarm icon, the LED status fixes itself and begins to show correctly. You can see in this picture the LED lights up to red immediately after I touch disarm:
If you interrupt sleep mode by tapping on the screen, does the LED turn on correctly? Does it then turn off when the panel goes back to sleep?
Does the light come on when you touch the arming icon, or when you actually change the arming status of the panel?
