IQ Pro sensor configuration
With the IQ Pro now using the Installer app for all configuration, is it still possible to access and modify sensor or key fob configuration other than through choosing sensor groups and whatever device configuration shows up in the Installer app?
Specifically, I wanted to configure my PG9949 button 4 (both buttons pressed simultaneously) to be Disabled instead of triggering a panic, and configure button 1 to go straight into Arm Away instead of incremental arming.
If this isn’t available through the app, does adding a Corbus wired keypad allow for accessing some of this configuration the old way ([*][installer code][804]etc…)?
Mike
Programming must be performed using the IQ Installer app, and while there are some additional options on a Powerseries Neo for PowerG keyfobs, currently only the configuration options available within the app are accessible for the PG9949.
This is the same as on the IQ Panel 4 using the panel UI. Some sensor settings and behavior can be adjusted depending on the sensor, but all granular changes aren’t available.
