Can you point me to the procedure to wall mount my IQ panel? I will need to shorten my power cord so I will need to disconnect the power etc…
See starting on page 9 of the installation manual here.
Thank you for the link. I think I know the answer but I’ll this anyway: Should I completely power down before disconnecting the power and back panel? The power down instructions also say to remove the battery .
Yes, on the panel go to Settings > Advanced Settings > Power Down. That will turn the panel off first.
should I remove the battery as well?
You just need the panel powered off to mount the panel. Make sure the transformer is unplugged when connecting wires. After the panel is mounted and closed up, plug in the transformer.
Great to hear. Thank you for all your help
