mfrenkie
(Mark)
December 31, 2024, 1:21am
1
Hi, I have an IQ panel 4 and the remote panel screen will just start rapidly turning on and off for no obvious reason. I don’t think it’s a power issue because it doesn’t make the noise like a power supply is being disconnected or reconnected. Any ideas?
jwcsurety
(Jason)
December 31, 2024, 1:41pm
2
Is that the IQ Remote PowerG model keypad?
The first thing I would do is reboot that keypad. Next, update firmware on your IQ Panel. Steps to update firmware are described here:
IQ Panel 4/IQ4 HUB/IQ4 NS - 4.5.2 SOFTWARE UPDATE
Fixes/Improvements:
Corrected an issue where PowerG PIR Cameras may drain their batteries prematurely
Update Instructions:
Compatibility Note: Your IQ Panel must be on software version 4.4.0 or higher and connected to WiFi to install this updated wirelessly.
Swipe down from the top of the screen and touch “Settings"
Touch “Advanced Settings”
Enter a valid installer code (default is 1111)
Touch “Upgrade Software”
Touch “Patch Tag” and enter th…
Does the behavior continue after that? If so, try powering it from another receptacle.
