I’m guessing not as I’ve gone through all of the settings I can think of looking, but is there a way to have the panel default to the arm screen so when leaving all that has to be done is wake the panel and hit arm away/stay versus having to first enter a user pin/select user then arm it? I’m used to the 2gig style where the arm/disarm option is just the default screen and it’s so much faster exiting than having to stop and enter code, wait for it to log the user in, then select the arm commands.
This is caused by the Screen Lock feature. This is not a default feature, and can be disabled if you are only using one partition.
If you have multiple partitions enabled however, it is a required feature and cannot be disabled. It looks like you may be using a second partition.
Screen Lock is found under Settings > Advanced Settings > installer code > Installation > Security and Arming.
Thanks for the reply, that was it. It’s actually working for me disabled even with 2 partitions (if this is a glitch please don’t fix it, ha); I assume it could be because I do not also have it set to require a code to arm the system, only to disarm.
