ok thanks,
But the repeater will definitely work with the S-line sensors?
so anything changed since 2 years ago when you said the repeater won’t work at all with the IQ Panel 2?
Ah, I see what you are referring to up top. Never said the Repeater won’t work with the IQ Panel 2+, it will not repeat S-Line encrypted signals.
The original response needs updated because it assumes S-Line sensors will always be encrypted, but they actually transmit both encrypted and unencrypted signals. You program the panel to listen to one or the other. Thanks for pointing that out, we’ll fix the original response. I don’t recall if it was available at the time to choose the signal source.
If looking to buy new, or if you just have issues with a handful of sensors, I’d still strongly recommend going PowerG if you have the IQ Panel 2+, as it will probably be cheaper than an RE524X and will be encrypted.
