I’m setting up a new IQ Panel 2, and I’m not having much luck adjusting the screen timeout to below 5 minutes. The only place I can see to adjust this is in the Picture Frame settings menu (set display to none, and then timeout to 5 minutes).
Is there another place this can be adjusted? I would prefer something like 30 seconds 1 minute.
The timeout settings are found under photo frame settings. You can select to have the screen revert to photo frame, or to turn off the screen, minimum 5 minutes currently. We’d be happy to request shorter times from the manufacturer and see if that can be added in an upcoming update.
