IQ Keypad (IQKP-915) - Use for only one partition?
I’m looking at purchasing the IQ Keypad for my Shed (partition 3). When I pair the IQ Keypad, can I set it up to be default to that partition? Or do I need to hit #3 each time before I enter the access code?
You can select which partition the IQ Keypad is associated with in panel programming.
For example if you associated the keypad with Partition 3, arming the keypad via the Stay or Away button will arm that partition. You can then disarm that partition by entering a user code that has partition access (either a User with partition 3 access or the Master User)
From the Keypad you can still disarm partition 1 using #[1] + Master User Code.
