I am in the process of self-installing a new (no existing components) security system and, while reading the IQ Panel 4 Installation Manual I came across the IQ Installer App. It appears that this App would make a solo DIY install much easier by eliminating the run back to the panel each time tamper a newly installed device. In the FIND IT section it is claimed that if I go to SETTINGS, ADVANCED SETTINGS, ENTER (dealer or installer) CODE, I will see an icon captioned IQ INSTALLER. Don’t see it, can’t find it, ain’t there. Can anyone provide some direction?
The IQ Panel 4 is compatible but it requires the panel to be on firmware version 4.5.0 or higher. You are currently on 4.4.1 so you can update to the latest version number which is 4.5.2
To update your firmware, follow the instructions in the firmware release update. You can update by entering in the patch tag
