Integration of driveway gate?
I have a 2GIG GC3 system in my house, and a fair amount of integration - wifi garage door, thermostats, some lighting.
We recently installed a driveway gate and I’d like to get that integrated with the alarm.com app both for knowing when it’s open/closed and to actually open and close it.
Any suggestions on products to do this? I figure z-wave or wifi would work, but I’ll need some sort of sensor to determine gate position as well. I see there’s a z-wave garage controller on the website, theoretically this should work except it uses a tilt sensor and the gate swings open, so I don’t see that being effective.
Appreciate suggestions!
You can use a compatible MyQ gate operator.
Look into the MyQ options here:
Appreciate it, but the gate and operator are already installed, and it’s not a liftmaster product (it’s Viking). So I’ll need something that is basically generic.
How long is the driveway? These are typically out of zwave range.
I’m not aware of any dedicated retrofit gate operator. In the past a handful of users have attempted to rig a solution with relays and Z-wave switches, but there is no status feedback or safety measures like in a purpose built compatible operator like MyQ. I would not recommend trying to rig a solution with an incompatible opener.
It’s actually right next to the house, should be well within range.
Ok thanks
If you’re willing to go through the trouble and expense, you can safely build a workaround that implements all safety features. It’s going to be a bit clunky and complicated though. Almost certainly better off just buying the new opener and selling the current one.
