The ADC-VC725 from Alarm.com is a high-performance mini bullet camera optimized for indoor and outdoor video monitoring. Its compact design and outstanding HD quality video make the camera ideal for both commercial and residential video installations. The camera features a dust-resistant exterior casing with an IP66 rating and Power over Ethernet (PoE) capabilities.
Features:
- Power over Ethernet
- IR night vision
- HD video
- IP66-rated waterproof & dust tight
- This allows the camera to be mounted outdoors
Specifications
| Live resolution options | 1280x720, 640x360, 320x180, and 176x100 |
| Recording resolution | 1280x720 |
| Recording compression | H.264 |
| Image sensor | 1/2.8" Progressive Scan CMOS |
| Lens | 4 mm, F2.0 |
| Angle of view | 85° |
| Low-light sensitivity | 0 lux with IR |
| IR range | Up to 30 meters (~95 feet) |
| Image adjustments | Brightness, contrast, saturation, sharpness |
| Video motion detection | 3 windows, adjustable sensitivity and threshold |
| Ethernet connection | 10/100Mbps RJ-45 |
| Password authentication | “Digest” authentication |
| Simultaneous viewers | 6 |
| Operating temperature | -30°C – 60°C (-22°F – 140°F) |
| Operating humidity | < 95% (non-condensing) |
| Max power consumption | 12 V DC ± 10%, 5 W, PoE (802.3af) |
| Dimensions (LxWxH) | 70 x 154.2 x 60.5 mm (2.8 x 6.2 x 2.4”) |
| Weight | 500 g (1.1 lbs.) |
| Ingress protection | IP66 |
