Have two in wall micro switches. One discovered fine the other will not discover. The light switch itself works. What could be the cause? I’m taking the panel to the switch and turning it on and off but will not find.
Have you attempted to remove the switch first using the remove device function, then add? See this post for general Zwave instructions.
No, but I will try tonight.
removing first worked. thanks for your help.
