I’m trying to install my image sensor and it is not working, the menu says requesting authorization code from provider. I have V1.12 firmware and the 2GIG 900 MHz Transceiver (2GIG-XCVR2-345).
Have you attempted to reset the image sensor using a paper clip, learning it in in that fashion? The image sensor may have not fully registered during the pairing process?
Edit: It looks like an Image sensor has been learned in successfully. Is that correct?
