I have the control pad but no cameras
Is anyone else completely satisfied that you can’t speak to anyone? I’m just trying to get something set up, I have a tablet/control that is compatible but no cameras. I dont see how you buy some things but not others and I can’t believe I’m the only one who is struggling to do this without someone talking me through it?
Hi, it sounds like you are just looking to start service, is that correct? If you have a compatible alarm system, you can get started at the link below:
Enter your system’s IMEI to check it’s status and make sure it can be registered, and then select the plan that best suits your needs.
If you do not need camera support, compare the Alarm and Home plans, those do not include video services.
Do you have automation devices like lights, locks, or thermostats connected to your panel? Connected garage door? If you need automation support choose Home. If you only need alarm sensor monitoring, choose Alarm.
If I’ve misread and you need to buy other products, our store is found here, and if you let me know what you are looking for in reply we can help direct you!
I have a compatible activation ready control pad, but need cameras, i dont know how to buy cameras or other door sensors and also get a plan.
Plan pricing and features can be found here. As service is offered on a month to month basis, plans can be changed at any time. To begin service, purchase the service plan that best suits your needs. After purchase, the website will walk you through the account creation process. Provided you have an unregistered, 4G LTE module, it takes about 5 minutes from service plan purchase to account setup and connection.
If you will be using the system without cameras for now, you can use Surety Alarm. If you will be adding cameras later on, you can then switch to Surety Protect or Surety Complete.
Alarm.com cameras can be fount in the link below
