Wire the ADC-VDB750 to two digital chimes
- On the first power module, attach the white wires interchangeably to the FRONT and TRANS terminals on the first chime.
- On the second power module, attach the white wires interchangeably to the FRONT and TRANS terminals on the second chime.
- Wire one terminal of the transformer to the TRANS terminal of each chime. A wire connector may be used to simplify the wiring at the transformer terminal.
- Wire the ADC-VDB750 to the FRONT terminal of each chime. A wire connector may be used to simplify the wiring at the doorbell backplate.
- Wire the remaining terminal of the transformer to the ADC-VDB750 backplate.
Wire the ADC-VDB750 to two mechanical chimes
Note: The resistor or mechanical chime dongle can be used as normal, if required, on either or both of the mechanical chimes.
More information on the VDB750 can be found here:
